Hello, the test for the new FW is only for people who have installed the beta?
Official FW
- Eric33
- Closed
Hi Eric, is that a question or an assumption? I wouldn't of thought that was true, there's no logic in it. The new firmware will be available for anyone to install 👍
There is no logic to reset to update.It's like having to make a factory return for an android update
For me this manipulation and to do for people who have installed the beta.
There is lots of logic in factory resetting after a major firmware upgrade Eric, its not just something they have pulled out of the air, it's very much needed if you want a stable operating experience 👌
Ben no there is no logic, go for a ride on the forums, we will not reinstalled our action app after each update ....
I'm not following why this would make you so frustrated Eric, it only takes a few minutes to get your box back up an running again an the forum is here for any help needed should you require any help. Have a nice day 👍
Is the official update here?
ive just got it and updated
May seem obvious question but please bear with me.
When I factory reset after update does Mytvonline2 reinstall automatically please ?
Other than that I think I have all my soldiers in a line, ie apps to reinstall, log in details, passwords etc 😉
Microo stuttering is still occuring on official update
All channels or some?
Yes it did 👌 if not just run the update manually.
Thank you 🤟🏻
please use official thread for new update! We have now this one and other, spreeded informations!
Close others Sam 👌
It is better to do the factory reset and clear the box from all the beta updates and start fresh with the official release
Some
