Usb recording
  • Hi guys,
    Totally brand new with this z8 box so please bear with me ,
    I’ve owned it for approx 2 hours, it’s set up, suppliers url is running and all’s fine .
    The issue I’ve got is regarding usb recording , I’ve connected a 1Tb hard drive through the usb 3.0 port, went into settings and formatted it for storage .
    But when I test recorded it on a random channel, nothing popped up on screen saying it’s recording or anything, and when I went on the list of recorded things through the remote it’s saying nothing is there ?
    I’m wondering if the 1Tb is too large ?
    The annoying thing for me is, I set off for the airport in 3 hours so havnt much time to mess about it until I return in a week .
    But if it’s a simple option I haven ticked in settings or something I could try before I go.
    Also, is recording of Iptv channels supplier dependent, if they don’t have that function then I can’t record regardless ?
    Sorry for sounding like an idiot, but to be honest I am 8o
    Cheers guys :thumbup:
  • Hi,
    check this post and follow the text and picture -> which USB key is recommended for recording ?
  • Thanks Sam , I’ll install that app when I return.
    I’ve tried again, I pressed record and the recording counter came up top right of screen.... fantastic I thought .
    I stopped the recording after 20 seconds .
    I then went to view what I’d recorded, but again...nothing is there ?
    Anyway, thanks again, I’ll reformat the drive the way you described and try again .
    :thumbup:
  • How many logical partitions exist on the HDD?
  • I wouldn’t know 175n sorry, all I done was ...
    I had an external 1TB drive, I connected it to a laptop and used the windows 10 to format it, it said something like full format or quick format,
    I went full format.... which took forever !
    I just then connected the drive via usb 3.0 cable and port to the z8.
    I’m in Benidorm at the moment and not back until this coming Sunday , so can’t mess on with it until then .
    Thanks for asking the question though :thumbup:
