Official Firmware 2.8.71 / MyTVOnline 1.9.71 for Z+, Z, Z prime and Z nano
  • Formuler Z-series official software released. (Excluding Z8)
    Firmware Version : 2.8.71 or 1.2.71 (Device dependent)
    MYTVOnline : 1.9.71
    WARNING: Install and use at your own risk. Software cannot be rolled back after installation.
    Change Log
    [SYSTEM] ADD: Mini app market for Nano
    [SYSTEM] FIX: Internal WLAN dropping issue
    [SYSTEM] FIX: Display Resolution button doesn't show resolution selection window
    [SYSTEM] IMP: Display resolution selection window only shows compatible resolutions
    [SYSTEM] FIX: System software update hangs when system memory is full
    [SYSTEM] IMP: Improved front panel boot-up LED sequence
    [SYSTEM] FIX: Android Location Services
    [MOL] FIX: Radio channel streaming issue on certain portals
    [MOL] IMP: Increased refresh rate of detailed stream info
    [MOL] FIX: Episode playback issue on certain portals
    [MOL] FIX: Crashing issue when switching portals
    [MOL] FIX: Favorite list changes if m3u list is updated
    [MOL] FIX: Page scrolling issue in TV Series section
    [MOL] FIX: xmltv EPG parsing issue
    [MOL] FIX: Cell overlap issue in Program Guide
    [MOL] FIX: HLS VOD playback issue
    [MOL] FIX: Group Channel Numbering preference changes after applying Installer Mode config
    [MOL] FIX: Recording stops if stream buffers
    [MOL] FIX: m3u channel parsing issue
    [MOL] FIX: TV Series playback/seek issue
    [MOL] FIX: Favorite channels disappear when using XC API
    [MOL] FIX: Freeview HD EPG display issue when using USB DVB-T tuner
    [MOL] FIX: Timeshift file is created on USB even if Timeshift is set to OFF
    [MOL] IMP: Grid EPG data request rate
    [MOL] ADD: VOD Favorites
    [MOL] FIX: VOD Search not working with XC API portals
    Various bug fixes and performance improvements
  • Yeah. I did today and it seems to have sorted my problem which was defaulting to home page every time I changed channel or selected epg. All good so far...
  • Hi Guys,
    So I've updated around 20 Z Nano boxes myself so far and had my clients perform their own too, but I had one today which has now gone into an update loop.
    The box boots into "preparing to start" I sometimes see an "open vime from client" message flash up then it goes to the SW update page and shows 1 update to FW v2.8.71 from v2.8.13, the current IPTV version is v1.9.71.
    By forcing it onto the red SYSTEM page (remove Internet) I can perform a factory and software reset, then reboot, but it still comes to the same page, I've also tried the Beta v2.8.70, but the same happens. I can access the MTOL uninstall command in Menu/System/Android/Apps/MyTVOnline, but am afraid to do so because I have no way to find or get the APK or aptoid to load if I uninstall it.
    I see other users with this same issue, at the moment I only have 1 box like this, I have over 120 boxes out there and fear this issue will cause me a lot of heartache if it cannot be resolved quickly.
    I think the issue is with the IPTV v1.9.71 SW causing it not to update through Android, but doing a SW Reset does not roll-back this to force a new IPTV update. I do sometimes get an IPTV Updating... Downloading... Installing... message before it gets to the SW Update page again, but it makes no difference and now I'm stuck.
    Any pointers would be a tremendous help since I know this is going to hurt me otherwise. Can I get both the IPTV and FW updates to load from a USB? I feel the issue is the IPTV SW, not the FW update, so the 10MB file, not the 120MB one.
    Thank you kindly for an otherwise superb little OTT player - until now...
  • This is not installing. First I accepted the install and went away for an hour, came back and O.o Mb had been downloaded. So I powered off and on again, Now there is a 2 symbol of the update button in the settings. When I press the Update button the update dialogue flashes and then nothing. How can I update without reflashing the device.
    Which model are you using?
    Based on the way you spell some words, I am guessing you live somewhere in the UK.
    Are you using Sky/Virgin/BT ISP supplied networking hardware? (modem/router)
    If so, you may need to go into the router settings to turn off the extraneous security settings and firewalls settings so the update will work.
  • I am using a Z7+ without 5G. I am in Belgium. I finally managed to download the firmware (by resetting the software and pressing the cancel button on the update popup once). Anyway, after the update, I have the 1.9.71 firmware and version 2.0.0 of MYTVOnline but it keeps trying to update to 2.0.1 and showing a "fail download" message. Other apps have no problem with the network connection. How can I either disable the download for the update or change network settings to get it to download because now I can't use the MYTVOnline app.
  • Unless there is a specific reason there should not be a need to factory reset, no do I expect that it will work since network issues will persist.
    Please provide accurate information on the version of software installed on your device so we can better assist you.
    • Firmware Version:
    • MYTVOnline app Version:
    • SW Update app Version:
  • Optional Cumulative Hotfix for MYTVOnline is now online : 1.9.75.
    Change Log:
    FIX: Software Update Loop
    FIX: Favorite channels not working on certain XC portals
    FIX: Mini Market not accessible if no portals are installed (Nano)
    FIX: HLS streams don't auto-recover after network instability
  • MYTVOnline 1 : 1.9.80 Official HOTFIX
    The main fix in this patch relates to a compatibility problem with xtream-editor services that caused MOL1 to crash shortly after portal login.
    Change Log:
    • FIX : XE Channel ID issue
    • ADD : VOD/Series Favorite Category
    • IMP : Restrict VOD metadata HTTP request rate
    • General Bug Fixes
