Which remotes are compatible with Z8 that have a Microphone?
  • Hi All,
    Quick question - does anyone know if there is any remotes with a microphone that is compatible with the Z8?
    If there quite a few, I would love any recommendations. Thanks! :)
    Edited once, last by Endymion ().
  • Curious what you would use the microphone for on your Z8?
    You can try to pair a generic bluetooth remote that has a built-in microphone.
    I successfully paired the Nvidia Shield remote to the Z8 and it seemed to work. Didn't test the mic however.
    To be honest, the reason why i am asking is because there is various 3rd partys app I use on the Z8 that has a microphone option embedded in their search function.
    Do you still have the nvidia shield remote connected to the z8 - if so, would you mind testing it for me? I'd love to purchase it if it works.
  • Shield remote pairs with the Z8 OK, but the mic doesn't work for some reason.
