Customize /etc/remote.config?
  • Sam,
    Is it possible to load a custom remote control config file. I have several remotes that I prefer to the stock remote supplied with the Z7+. For example, my old Rogers remote can shut down the TV and audio equipment when I power off, as well as control the volume through the amp. I can easily dump the IR codes for the remote.
    Dave
  • Quote
    Sorry but not possible. In your case would maybe some universal rcu like logitech be good solution. One rcu for all.
  • Sure it is possible. It's software.
    Seems like a waste to spend hundreds of dollars (3 TV's) on new programmable remotes. I guess I will get a JP1.x cable (<$20) and program the Rogers remotes to the codes you accept. After all it is just software.
  • Hi
    Z7+ operate tv but does not operate box ?
    any ideas ? do i need to press and hold STB or anything as i have tried with no luck
  • Hi
    You need to tell us more. Does your remote blink when you press a button, or does infrared light in your box blink? If you're using IR cable try to take it off and point directly to the box and try.
