MyTvonline and StBemu
  • I have StBemu app installed on my Z8 which I used successfully to connect with my Provider's IPTV URL when there was the issue with MyTvOnline2 which was solved with Mac Address refresh from Provider's part. I since left StBemu installed just in case. Today I tried to connect with StBemu instead of MyTvOnline2 but connecting gives device blocked by provider error. Why does this happen if both apps use same device Mac Address and I only use 1 app at a time. So I cannot have more than 1 app configured for same provider?? MyTvOnline2 connects without issues. Many thanks
  • your provider has now removed the mac from stb emu thats why you are geting blocked by provider
    so you can only use 1 line as its easy to chance the mac on stb emu and ues it on another device
    Ah! I see.....because you can write your own Mac Address on StBemu and so use the connection on another device which is not allowed. Ok..now i get it...thanks
    You can use the same MAC with MOL2 and stbemu, but it involves some work. See this thread for details:
    Information sent to MAC portal for identification
    Closed the thread.
