App on 2 lines
  • To activate and use Launcher Settings on the Z8.
    Go to bottom of home page to Launcher Settings.
    • App groups
    • Choose a group
    • Enable Activation toggle
    • Name the group (Type in name using the virtual keyboard and select the enter key on the keyboard when you are finished)
    • Select apps (you can save them in order you want them to be on screen or just move them later easily)
    • Press back 4 times to get you to home menu, check the new group you created.
    • To move apps in order just hold down on the app icon with the ok button, then move the apps around.
    *The locker app group is the same except you have to create a pin that will be used to enter that group every time. This group will always be locked and apps inside hidden*
