Hi, YouTube is not working on my Formuler Z Prime and says that he need an update.
When I go to market I don't see the YouTube app.
Even with Google Play it didn't work.
What is the solution?
Can this topic also moved to the right section, thanks.
Deinstall current app, restart the box and go then into Market, YouTube app should be shown. If not, try again with your Google play account and install new one. Versions over 2.x supports 4K.
Does that mean when you goto:
Market => My Apps => Updates
The Youtube update is not listed?
Take out your youtube app and go to markets and you will find it on the first row . do not go to my apps , it is only to show what apps you have in your systm .
I have uninstalled the YouTube app and restarted the box.
After then I went back to market and still no YouTube app.
There is another app called Smart YouTube TV, but I prefer the official YouTube app.
My other box Z7+ has no problem, YouTube v2 is available in the market.
The Z+ is same like the Z Prime, no YouTube official app in the market.
No problems on the Z Nano, YouTube is working and doesn't need to be updated.
I have Z+, and I deleted YouTube and redownload it from Google playstore and it's running fine.
It asked me to update Google play services, but after that I can use Youtube.
The one from Google Play is that the YouTube TV app?
This one is for mobile/tablet.
I need YouTube for Android TV app.
The mobile/tablet version is not user-friendly on boxes
But you know that z boxes doesn't have Android TV OS and so some apps that working with Android TV OS will not work on z boxes.? So, mobile version is right one..
Yes I know and you know that this device is released with YouTube TV version.
My question is will Formuler solve this YouTube issue by releasing an update?
From what I saw is that other manufacturers updated the YouTube app on their boxes.
Google killed support for Youtube TV 1.2.7
Developers are aware of the issue. It will be patched in tomorrow's release.
If you can't wait, download and install Smart YouTubeTV.
or
find and sideload YouTubeTV 1.0.5.5. It will allow you to bypass the "Update Now" screens
Thanks for the info
YouTube is not working again.
Will this be solved?
Problem comes from Google. Google blocked all old versions of Youtube app.
https://support.google.com/youtube/thread/14781942?hl=en
Install and use Smart Youtube TV
The Smart Youtube TV app doesn't work stable.
How do you know this is caused by Formuler software?
Perhaps create a support ticket at Google?
Read good!
Where do I say Formuler?
I tried the Smart YouTube app and it's very bad end slow. So I prefer the official app.
If Google is the reason then nobody can blame Formuler off course.
Btw it's normal that users ask questions about issues they have.
Hopefully this YouTube problem can be solved.
Start Smart Youtube TV and press the BACK key to access the Smart Youtube TV startup options.
Select the "Lite" interface to see if it fixes your stability issues.
unfortunately also Smart Youtube TV does not work. Tried all options ( also the "lite" version ). The launcher does not start the app.
Use the version that is available in the Market app.
That is what I did, but unfortunately no success. After waiting a while when app is trying to start, it says something like " try different launcher". Tried them all but does not start.
Thanks, it works much better now.
When will resolved this issue with official youtube app?
Ask the Youtube app devs?
