Is is there a way to turn on group channel numbering in MYTV Online 2?
Channel group numbering
- MYTVOnline2
- jkakarot27
1. Open MyTvOnline2
2. Press menu button, go to Portal tab
3. Click ok button on your connection
4. Click Edit
5. Scroll down to Group Channel Numbering
6 Click ok to turn it on/off
Hello
what will change when you turn it on
All channels in each category starts then with 1.
Happens sometimes when the provider work on channels, box restart or connect restart fix in most cases the issue. I had yesterday the same with some test provider.
is it possible somehow to sort Fav. channels with Channel group numbering ?
If you installed today's new update, then yes. Activate under Connections -> Your sub ->Edit
i cant find it your sub edit
I found, numbering of the chains by group, in the portal but after we do how? Thank you
SAM thx for promt sevice. actually i shold test first, bevor boadering you. i install allredy the beta firmware and make my Fav list allredy, but the nummbering was still old. after update to official, firmware nummbering was as it should.
@ Dremman 1. Menu
2. connection, press OK button3. choose your connection, press OK button
4. choose EDIT, press OK button
5. choose Group Channel Numbering and turn it on
now you can edit your Favorites and they have nummbers 1,2,3,4...
Thanks, it works
Ok, channel numbering is switched on and I am in my favorites...
Now, lets say I have this channel setup.
1. Channel 1
2. Channel 2
3. Channel 4 (This channel is called Four)
4. Channel 3 (This channel is called Channel Three)
Deliberately renamed 4 and 3 so you have to move them manually. A simple alphabetical sorting button wont help here.
How do you move them? I want 3. and 4. to switch places, manually... -
Press channel that you want to move with OK and hold.
Thank you!
Ok, I've been trying this now and I cannot get it to work at all. The thing that pops up is PiP, the little mini window in the upper right corner. I can switch between what is on the big screen and the little screen by holding down the red key. However, there is no way that I have managed to switch order of the channels in my channel library.
If I open the library by pressing (OK) I get choices down in the right corner. Red key says SORT. I have 4 choices under sort...
LCN
A-Z
Z-A
USER
I press these and they highlight and go back to the channel list... However, when I press channels they just switch channels on the TV like any remote... If I hold OK on the channels, nothing happen... I expect a menu of some sort asking me, (under what number do you want this channel?) But, nothing like that at all shows.
However, I have found a solution but it is a pain in the ass... I can remove favorites and then re-add them in the order that I want them. Then they go into the right places because I add them in that sequence manually...
Please check this two screenshots:
Oh I see... I have to create my own group... I thought I could use "favorites" (the one that places a star in front of the channel)... I'll try this... Thank you!
There was another "page" where you can edit the groups if you "backarrow" (The page that you are displaying above, I didn't know)... I don't have to create anything... Can use the existing "favorite" if I wanted too...
Thanks for your help Sam... 🙂
Is this possible in MyTVonline 1 ?
