Remote Control pauzing
  • Hello everyone,
    Hope someone can help me.
    I can't pauze on any channel a live footballgame with the remote controller.
    Any one else who also has this problem?
    Thank you
    Fabio
  • Basically yes.
    You can open the Z8 file explorer app to see if the storage device is supported/connected if you can see/open files, or if it is empty the Z8 should display the amount of free space. (Home screen > Settings > Storage > Removable storage)
    It is recommended to always use the USB port on the right side, it's the "blue" one, because it's 3.0.
    I recommend to use NTFS as filesystem type.
    Sometimes it is required to use Windows "diskmgmt.msc" (or the Mac/Linux equivalent) to first create a disk partition before you can create a volume on the usb drive. To keep things simple make sure the partition and the volume are both 100% of the drive.
    Edited once, last by ddd ().
    Added the Label Solved
