good afternoon
When I was installing the box, I tweaked the EPG settings. Now my EPG doesn't give me any information. Do I have to install everything from scratch again?
good afternoon
No you don`t need to do that. What exactly did you done with epg?
good afternoon. I bought the Formuler Z8 a week ago. When I installed the box and mytvonline 2 maybe made some mistake in EPG. In the meantime I have already solved it. I went to EPG calls and none. But I still don't have information (EPG). I have a m3u list and the problem is not from my server. Is it a MOL problem?
You need to add an epg link "source" provided from your provider if you connect via m3u playlist otherwise try connecting via XC and see if the epg will work then.
All of this what Mevi mentioned, you can find in this Article -> How to use MAC/ID portal, Xtrema Codes Api (XC) and M3U Url on Formuler Boxes.
Should each new box user read first. There is also one part how to generate epg xmltv for your m3u connection.
Yes I have been reading. Where do you say you have to put passwors 11111 and 22222 ... I send a screen of my MOL2. My server says his EPG is good and says he can't help me. I think it's his ill will.
Add in portal not playlist.
Attachment deleted because of visible provider url!
The username 11111 and password 22222 in Article is just for example, you have to generate xmltv epg url from your existing url.
And include, see picture:
