MyTVOnline 1.9.93 problems?
  • Hello guys
    3 days ago I bought my first formuler.
    I having a lot of problems on all my live tv channels, frezze, buffering, jiltering
    Do you know how to solve this?
    Thanks a lot
  • Did you update the box to the latest official software?
    Are you using MyTVOnline app when you see these problems?
    What if you try to play (HD) video's in the youtube app? Is that better or do you see the same issue?
    I'm one the last firmware.
    I tried one VOD and it's ok. For the VOD, do I have to download somekind of codecs if I dont have sound?
    I can try Youtube later.
    Youtube HD Video -> ok
    VOD MyTVOnline -> ok
    Live TV (SD HD FHD) MyTVOnline -> notok
    What can I try/do?
  • Hello,
    What can I try/do?
    Sound like a problem with your service provider, or your ISP is throttling.
    Install and use a VPN on your Formuler and try again. If the VPN does not help, try a different service provider.
