Since a few days single EPG is not loading anymore, but Multi-EPG (Grid EPG) is ok.
I am connected via portal (MAC) and Firmware 1.4.46, MTVO2 7.5.6-1638-14723fd0.
I see the same sometimes with my provider... I assume it is a provider issue... did you ask them already?
Hi ddd,
thanks for your reply. Probably you are right. I tried with another provider and there it loads the single EPG. Just thought because the multi EPG is working the data must be going to MTVO2. But that assumption was wrong. So I think the EPG problem comes from their side. Another thing is that the EPG description of the show is sometimes wrong and doesn't correspond with the title.
For those reasons I pay for my EPG so I don’t have to rely on providers EPG cause most often they don’t work properly.
This was fixed in the current beta software and the official software containing the fix will be released on or around Jan. 7th.
Can you confirm the version of MOL2 you are using?
Mol2 7.5.6-1638-14723fd0
looking forward to the next update
I have the same issue. No single EPG while watching the program from 2 different providers. Any help is appreciated. t
Change EPG from Normal to UTC and test again.
All better now. Thanks
I have the Z8 and I can't have the EPG. How do I get the EPG from normal to UTC? Where do you do it? Thanks
EPG Mode under Mol2 Menu -> Connections -> your subscription -> Edit -> EPG Mode -> Normal and UTC
epg not working anyone else having problems
Epg not working (playlist m3u) after update
Working fine for me using xeev via portal.
Changed Normal to UTC in settings and "boom" all better. Thanks for the help
Good afternoon Sam
I followed the steps you gave me and I can't see how to see this from Normal to UTC. I will send a picture of MOL2 together.
Is not shown in Playlist, use your m3u url data and create XC Api portal. See how to -> How to use MAC/ID portal, Xtrema Codes Api (XC) and M3U Url on Formuler Boxes.
Still having issue ( program title is different) with single epg after change to UTC.
it was ok before the upgrade. I was using normal
Any thoughts?
mine not working since update
i read all comments and decided to update my z8, in the moment that update finish epg stop working it's the second box that i update same thing epg dissapear.
it only appear when i click button EPG in the remote control, i think you call that EPG GRID.
in channel list only says NO INFORMATION
thanks
