I got a problem in the last week after the software update with Mytvonline2. Basically most of the time it does not connect and the error code 7 “check your internet connection or portal URL”. After several attempt it might connect but as I try to change channel then blank screen on all channels.
I contacted my server provider and there are no problems and all my friends with the same provider and different apps don’t have any problem.
anyone can help?
thanks in advance
