Hello, after last update my Recoding button cannot start . I can see the targets SD CARD and USB DEVICE (UNKNOWN (UNKNOWN))
If I want to start.... the records are not starting . In right corner rec 1:00 missing.
Last weeks I had no problems with Recording and now all is down. The USB Port is working..I can see all recodings from last weeks. and the SD or USB both have a lot off free space.
Why it doesn't work after the update to 1.9.94 before I can start with rec button without problems.
If I can start a record in last days abort after 1..2 min max. 70 MB) and after I cannot start the rec !!!!
What can I do to starting recordings again ????????
FIRMWARE RESET THE SAME PROBLEM !!!
