New firmware update for S-series devices has been released.
Download the latest S-series update from the Software Download menu in your device.
Firmware Version : v1.7.0
WARNING: Software cannot be rolled back after installation.
The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much longer then usual, please be patient and let the box finish the install.
Change Log:
Firmware Version: v1.7.0
- CHG : Newly designed Info Box Style
- ADD : Adjustment of picon size in Info banner
- ADD : Weather info, CAS info and network icons in Info banner
- ADD : Multi TP Scan function
- ADD : Picture Quality Setting
- Setting -> AV output setting -> PQ setting
- ADD : OSD Transparency level adjustment
- ADD : Installation guide -> Wi-Fi settings
- ADD : Manually add Wi-Fi network
- ADD : VPN menu access from home screen widget
- Enable RCU keys to move and select in VPN settings
- IMP : Sleep timer up to 4 hours
- IMP : Channel names and numbers shown on EPG search
- IMP : Satellite names simplified
- Factory reset required
- FIX : Launcher error when EPG searching by languages other than English
