I can understand bringing in a cheaper version box with MOL2 but ,sure less ram, less 1 USB, but by having a cheaper remote , feels like a cheap Chinese android box remote not the same feel as the Z8 and Z7 remotes awesome remote why did you not keep same remote for Alpha Model?
Z Alpha - needs better remote
Z Alpha comes with the same remote as the Z8.
dont use the remot controll extender if you realy dont need.
Is it the same remote as the z8 or not, also is this a good In your opinion
Don`t know who you ask, but like 175n say, it is same rcu like on Z8 and it`s good one.
just got the Alpha and already had a z8 and agree the remote is terrible compared to z8's. luckily the z8 works on both. and many saying its same remote maybe its where you get them but the one i got is defintitly not same as much smaller and weaker
you can see the difference here
for the small difference in price i stuck with another Z8
Like i know, delivered should be same rcu like Z8. Maybe goes the Distributor in your area other way and ordered the smaller rcu`s.
Is the z Alpha worth buying or is the z 8 the better box
If you overlook the specs (lower Ethernet speed, RAM, 1x USB port) and use it in most cases for iptv and 15-20 apps, you will never see any difference. Power users will always take Z8 because of better specs.
Both rcu are poor
You have to aim exaclty.
The big remote makes weird sounds when pressing the buttons
The little one is from bad quality.
To bad it has never been redesigned.
I have a Z8 and two Z Alpha, and they have the same remote.
i got them from World of satelite and the z8 from Germany.
Both rcu are poor
I’m sorry, but I’m going to have to disagree with you when it comes to the Z8’s RCU. It works flawlessly even without the Extender cable connected. There’s no need whatsoever to exercise precise aiming in any way, shape or form when it comes to the Z8.
I don’t know much about the Alpha, other than that, here in The Netherlands, I’ve seen them offered with two types of remotes. Both the one equal to the Z8 as well as the smaller one depicted here on a photo by slagheap .
If I’d have to choose between the two, I’d pick the Z8’s ZRCU any day, but since that’s the one supposed to come with the Alpha, there really doesn’t seem to be much of an issue. I am at a loss as to why some resellers seem to opt for the “inferior” type of remote (i.e. the one different to that of the Z8.
Can anyone enlighten me as to which RCU is supplied with the NEO? And where does the NEO sit in the gamut when compared to the Z8 and the Alpha?
Z8 -> Z Alpha -> Z+ neo
Like i know you (from your postings) i think you would be happier with Z Alpha
RCU from Neo is the smaller one. Personally i use the smaller one very much.
LOL… You’d be right about me being happier with the Alpha.. Only I’m inquiring on someone else’s behalf. And they might well be served perfectly right with the Neo, as they’d want a stable and affordable box with which to enjoy IPTV. Which you can do perfectly well with the Neo.
As for myself, my primary box is the Z8, and I might consider an Alpha as a secondary box, should I ever need one.
I have the 3 of them Z8, alpha, Neo, the RCU on Neo it's the smaller one, (personally i prefer the big one when I press the buttons).
I'm currently using the Neo plugged by cable and it works great of course if you only use for iptv, i also made a comparison in the speed of changing channels in between Z8/Neo and no differences, even if the neo have 1gb of ram.
Then if you would like a good in between choose the Alpha also for the price differences not that high and also because it can handle 2.4 / 5 ghz internal wifi when the neo only 2.4
Also the storage Alpha 8 /Neo 4gb and the neo do not have bluethooth.
All depends on your need but the Neo do the job !
