Yesterday I got some software updates to my Z8 box (v1.4.60) and after that I experience repeated crashes in MOL2, normally when using the EPG page. All of a sudden MOL just dies and I'm back to the Z8 start page. Sometimes I get a popup message saying that MOL2 died, sometimes I only get the start page without any popup.
Constant crashes after update
Crashing also for me sometimes after new update, and i have done factory reset and still crashing sometimes.
I had same problems after beta in Nov/Dec but working good after extra fix update in December
Same for me also, crashes almost every time. I use the latest normal version (not beta)
Please do factory reset in this case -> Factory Reset after firmware 1.2.71 and newer
Already done that and still same issues
Could you please explain in few words what is exactly connected with your box (kb, usb, bluetooth,etc) and installed apps?
When the crash exactly happens and what have you done at this moment?
Btw. all posts in this thread belongs into update thread and not in new thread..
After factory reset i only have used Mytvonline2 no other apps and it crashing when i go to channellist or epg and change channels
I had exactly same problems with beta in nov/dec and then u fix it with an extra update
What are you using, Stalker ID, XC Api or m3u url? The fix from last hotfix is also included in this update. Do you have some other subscription to test, maybe some 24h trial?
I have 3 different subs and all 3 crashing, i using portal and api
In this case open a new support ticket at https://support.formuler.tv and provide a detailed issue description. Thank You.
Same here.
Support ticket created.
I also have the same problem and as already described i am using portal connection. For me the crashes usually happens when I use the epg tio check what is on the different channels. Once I choose a channel and start looking at it it is stable. But going back to the epg and pushing Up or down a couple of times it crashes.
Same Here. I tried factory reset but didn't solved the problem.
Same here with portal or XC..
I also have that problem with crashes, not all the time but sometimes when I looking at EPG and choose some channel to look at. Sometimes just looking in EPG and browsing up and down, I use portal
Same here with portal and XC.
My Z Nano starts loading portal, Z+ and Z Prime goes to the home menu.
This happens when I change from channel or group.
