New beta released for Z8 / Z Alpha and MOL 2.
Firmware Version : 1.4.61 BETA Hotfix
MYTVOnline 2 : 7.7.0 BETA
WARNING:
HowTo Install:
Home Menu -> Software Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
Beta FW 1.4.61 - SW 7.7.0 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
We need to collect such data and feedbacks on one place, thank you for your understanding.
Fixes & Improvements:
- FIX: Ethernet port stops working after restoring a backup image from a different model **
The source of the Ethernet port not working on Z8/Alpha has been found. If the user/installer uses a Z Alpha backup file on a Z8 (or vice versa), the Ethernet port stops working.
A permanent fix that prevents restoring a backup image from a different model will be released on Monday or Tuesday. Factory resetting the device fix also the Ethernet port issue.
- FIX: Crash when viewing Grid EPG under certain circumstances
- FIX: API Portal > "Failed to load VOD data"
- IMP: VOD poster image size
- IMP: Language Translations
- Bug fixes and performance enhancements
