Air sync remote Z Mirror - changing channel
  • I love the mirror feature. works great for VOD. But I can't figure out a way to easily change the channel in live tv. The way I fonud was to click the back button then the super small channels icon at the bottom left.
    Is there an easier way?, I would have tought that hitting the screen would have process the 'ok' rcu equivalent.
    Rock
  • I believe you just swipe up or down for the channels. i don't think the mirroring feature is working anymore. Not since the last firmware and software update. I hope someone fixes it asap.
