SE:nO flashing
  • Hello,
    I tried to flash brand new Fromuler F4 Turbo to OpenATV 6.3, 6.2, Factory FW, Bootloader,OpenPli, but nothing work, still getting SE:n0 I used different flash drives
    The log ends with this:
  • The log ends:
  • What happens if you try with this image -> http://images.mynonpublic.com/…er4turbo-20200508_usb.zip
    Don`t forget to use the button on right side like in link posted from Rick.
  • Did it have anything on when you purchased. Where did you get it from
    My other half's sister had one few years back and i knew she wasn't using it I went and got it this morning and it flashed fine.
    I know this doesn't help much but i thought something may have changed
  • If you disconnect first everything (hdd, other usb devices etc.) except usb stick with image for install and try again?
    Try to install the bootloader again if accepted.
