Official FW 1.4.65 - SW 7.8.5 for Z8/ZAlpha (21.05.2020)
  • New official update released for Z8 / Z Alpha.
    Firmware Version : 1.4.65
    MYTVOnline 2 : 7.8.5
    WARNING:
    The install process and reboot works automatically! Please don`t turn off the box or unplug the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
    New Features, Fixes & Improvements:
    • ADD: Turn off Bluetooth pairing requests
      • Android Settings > Security & restrictions > Allow incoming BT pairing requests
    • ADD: Show recording icon in Launcher notification bar when background recording is in progress
    • IMP: Show active values for IP Settings and Proxy Settings in Android Network Settings menu
    • FIX: Portal credentials get erased when new remote config is deployed and overwritten
    • ADD: New User Interface for Live TV
    • ADD: Favorite Channels editor
      • Access from Live > Groups > Press LEFT
      • Add up to 10 different favorite groups
      • Arrange channels in your desired order
      • Up to 300 channels per group
    • ADD: Record one channel, watch another channel for multi-connection XC portals
    • ADD: Settings > HLS Fast Start ON/OFF
      • ON: Ramp up from lowest bitrate first
    • ADD: More Series metadata based on OSD Language
    • ADD: Direct channel number input from Grid EPG
    • IMP: Continuous play from Catchup for XC portals
    • IMP: Removed software update popup for non-essential updates
    • IMP: Move "View catchup in Grid EPG" option to Portal Settings
    • FIX: Catchup/Replay bug when local timeshift is enabled
    • FIX: Displayed fps does not match AFR fps
    • FIX: XMLTV EPG download issue
    This time with long awaited community features, we hope you like it :)
    Important Infos:
    The user assumes any risk of ban in this case! This depends fully from your provider and permission. Formuler is not responsible for any bans in this case. Pleas check this first with your provider before you use this feature with your m3u playlist.
    Is merge possible?
    If you have some question, please read first Beta thread, many questions are already answered -> Beta firmware 1.4.63 / Mytvonline 2 software 7.8.1
    Screenshots
    1698-formuler-00059383-jpg1699-formuler-00044262-jpg
    1700-formuler-00098894-jpg
  • When I’m now holding down V.Format to get picture options, it’s now bringing up the cursor, and I have to press the cursor button to get it away.
    Reproduced, thx. for reporting. Somehow is now 3th. command included. Should be fixed with next update.
  • Hey I’ve question about that AFR (Auto Frame rate),
    When I turnt it on, when I change from HD to FHD channel, For a second screen goes black and
    Then it reproduce the FHD channel. Now, when it’s OFF do I still get the FHD quality or 4K or not?
  • now changing between channels is slower spatially on epg
    i feel like the previous one was better and smother.
    i wish we can change between previous interface and the new one, will see soon maybe get better.
    Check in the setting if the Auto Frame Rate is ON if yes turn it off then you’ll have smoother changing channels experience
    Of course, you get the same quality but not the desired frame like some users want to have. Some users will not even see any changes in the video smoothness if AFR is On or Off. Must each user check and decide if he should use it or not.
    AFR is holding the video and need to change to proper frame. Turn off AFR in MOL Settings like iWanchek told, then the channel zapping should be fast like always.
  • Hi, I've only had my Z8 for about 3 weeks and I must say everything about the device and software is really great. And now with the ability to create several user favourite groups, it is even better. I do have a question - is it possible to rename a group, once it has been created? I've tried all sorts of key strokes, but not found it possible. Many thanks for your guidance
  • Hi everyone,
    I have a question, is it possible to turn off bluetooth completely?
    Also is it possible to change the position of favorite vod items, like holding down the ok button.
  • Hi
    I seem to have a problem on the new FW. When exiting from watching something on VOD back to live TV, the OSD remains on the screen over the TV channel and doesnt time out. Pressing back on remote does nothing infact all buttons pressed display over the OSD still visiblle. Going to standby and reloading mytvonline recitified. Not sure if it was a 1 off or a bug. Thanks
  • Catchup is messed up loads verry slow also says wanna start cloudshifting i normally never get that question..., normally i click it plays now stays loading also if you shift forward continue loading normally shit forward and starts.. catchup jumps van start to end out of nothing...
    Also epg loads slow
  • With a provider that has catchup the >>Info>>EPG data does not match Info and Grid Guide, when catchup is turned off in connection settings.
    When on a channel you press Info the correct data comes up.
    When using the guide button the correct info comes up.
    When pressing Info and then right arrow to go to EPG data the guide times are off by 2 hours.
    I am using EPG Mode set to UTC which should ignore any guide offset. When downloading the guide to xml I can see the channels do have an offset but this should not matter for UTC mode. "<programme start="20200521150000 +0200" stop="20200521160000 +0200" channel="globalns.ca">"
    It seems that the Info>>EPG way of viewing data is not honouring the UTC mode.
    Screen shots attached.
    Clearing EPG data did not alter behaviour. The same behaviour happens on multiple boxes.
    Using a provider without catchup does work properly when using UTC mode.
