Firmware update Z-Series
    Updates for: Formuler Z Prime / Formuler Z / Formuler Z+ / Z Nano
    _____________________________________________________________________________________________
    Updates 18.05.2019
    • MYTVOnline Version: 1.9.75
    Optional Cumulative Hotfix for MYTVOnline.
    WARNING: Install and use at your own risk. Software cannot be rolled back after installation.
    Release Notes:
    MYTVOnline Version 1.9.75
    • FIX: Software Update Loop
    • FIX: Favorite channels not working on certain XC portals
    • FIX: Mini Market not accessible if no portals are installed (Nano)
    • FIX: HLS streams don't auto-recover after network instability
    Updates 29.04.2019
    • Firmware Version: 2.8.71
    • MYTVOnline Version: 1.9.71
    Release Notes:
    • [SYSTEM] ADD: Mini app market for Nano
    • [SYSTEM] FIX: Internal WLAN dropping issue
    • [SYSTEM] FIX: Display Resolution button doesn't show resolution selection window
    • [SYSTEM] IMP: Display resolution selection window only shows compatible resolutions
    • [SYSTEM] FIX: System software update hangs when system memory is full
    • [SYSTEM] IMP: Improved front panel boot-up LED sequence
    • [SYSTEM] FIX: Android Location Services
    MYTVOnline Version 1.9.71
    • [MOL] FIX: Radio channel streaming issue on certain portals
    • [MOL] IMP: Increased refresh rate of detailed stream info
    • [MOL] FIX: Episode playback issue on certain portals
    • [MOL] FIX: Crashing issue when switching portals
    • [MOL] FIX: Favorite list changes if m3u list is updated
    • [MOL] FIX: Page scrolling issue in TV Series section
    • [MOL] FIX: xmltv EPG parsing issue
    • [MOL] FIX: Cell overlap issue in Program Guide
    • [MOL] FIX: HLS VOD playback issue
    • [MOL] FIX: Group Channel Numbering preference changes after applying Installer Mode config
    • [MOL] FIX: Recording stops if stream buffers
    • [MOL] FIX: m3u channel parsing issue
    • [MOL] FIX: TV Series playback/seek issue
    • [MOL] FIX: Favorite channels disappear when using XC API
    • [MOL] FIX: Freeview HD EPG display issue when using USB DVB-T tuner
    • [MOL] FIX: Timeshift file is created on USB even if Timeshift is set to OFF
    • [MOL] IMP: Grid EPG data request rate
    • [MOL] ADD: VOD Favorites
    • [MOL] FIX: VOD Search not working with XC API portals
    • Various bug fixes and performance improvements
    Updates 31.01.2019
    • Firmware Version: v2.8.60
    • MYTVOnline Version: 1.9.62
    Release Notes:
    Firmware Version: 2.8.60
    • Added Bluetooth shortcut to Quick Settings menu
    • Added ON/OFF switch in WLAN menu
    MYTVOnline Version 1.9.62
    • FIX : Portal init issue
    • FIX : Adult group bug
    Updates 27.11.2018
    MYTVOnline hotfix for Z-Series devices released Version: 1.9.55
    Patch Notes:
    • Inactivity timer improvements
    • FIX: Auto-shutdown issue
    Late October Z-Series Hotfix 25.10.2018
    • Firmware Version: v2.8.49
    Release Notes:
    • FIX: Eco Standby Mode loop issue
    • FIX: 'IPTVLauncher has stopped' boot-up issue
    • FIX: USB WiFi not recognized after soft reboot
    formuler.tv
    Updates 04.10.2018
    • Firmware Version: v2.8.42
    • MYTVOnline Version: 1.9.52
    After rigorous testing, the October 2018 Z-series software update is now available for download.
    We recommend all users download and install this update to bring better features and more stable functionality to their devices. Several critical bugs were patched in this software release.
    Thank you again to all the supporters and beta testers for making this release possible.
    Download the OTA software updates directly from your device using the built-in Update App.
    Release Notes:
    Firmware Version: 2.8.42
    • FIX: Stuck in standby mode
    • FIX: Market > Certain apps not showing in custom markets
    • FIX: Launcher icons not appearing after reboot
    • Added discrete Power ON & Power OFF keycodes (Zx, Z7+)
      • Logitech Harmony device profile updated
    • Custom Android hostname/device name supported.
      • Change from the system menu
    • Market shortcut can be deleted from the home screen
    • FIX: Installer Mode > SYSPIN issue
    • FIX: Installer Mode > Language preset not working
    • FIX: Installer Mode > Power mode preference issue
    • DRIVER: Add Tenda U12 USB WiFi adapter support (Zx, Z7+)
    • Android Security Patch Level : April 2018
    • General performance enhancements, UI improvements, and bug fixes
    • Improved Lithuanian language translation
    MYTVOnline Version 1.9.52
    • Fixed slow performance and crashes due to EPG memory issue
    • Teletext Subtitles supported
    • Manual EPG time offset. Access from the Settings menu
    • Xtream-Codes API portals > TV Series section supported
    • VOD > Continuous play option added. Press the Green hotkey to toggle
    • M3U > All tracks from VOD-only m3u list are parsed and used - regardless of stream file extension
    • M3U > Compressed xmltv EPG archives supported (.gz or .zip)
    • Automatically hide empty groups/categories
    • Added stream codec details. View from the detailed information popup window
    • TV Series Shortcut. Press and hold the VOD button on the remote
    • Remember last selected subtitle preference per channel
    • Improved channel icon caching
    • Improved EPG download performance
    • FIX: EPG description not displayed when using M3U + XMLTV EPG
    • FIX: Black subtitle font when only 1 subtitle track is available
    • FIX: RCU VOD hotkey while in Classic Channel list
    formuler.tv
    Update 04.06.2018
    • MYTVOnline Version: 1.9.35
    Update procedure:
    Release Notes:
    • XC Portal > Fixed VOD loading issue
    • XC Portal > Fixed Live TV and loading issues
    • XC Portal > Added xmltv EPG feature
    • M3U > Fixed VOD crashing issue
    • M3U > Added xmltv EPG feature
    • VOD > Improved appearance of subtitles. White font with black shadow.
    • Fixed DVB subtitle display issue
    • Fixed 'Stuck in Standby Mode' issue
    • Fixed MYTVOnline startup delay issue
    • Overall EPG performance improvements
    • General bug fixes and performance enhancements
    formuler.tv
    Updates 24.04.2018
    • Formuler Firmware Version: 2.8.13
    • MYTVOnline Version: 1.9.24
    Important Info: Z nano is not included in this update.The update for Z nano will come soon.
    Update procedure:
    • Please reboot your STB to receive the update.
    The April 2018 Z-Series software update has been released and is ready for immediate download.
    This update brings many new features and improvements that were requested from the community.
    Thank you to all the supporters and beta testers for making this release possible.
    Release Notes:
    • Fixed 'Stuck in Standby mode' issue.
    • exFAT external storage bug fixed.
    • Added programmable hotkey feature. System - Hotkey
    • Added new System Update app.
    • Added drivers for Playstation Dualshock4 controller.
    • Added support for USB3.0 Gigabit Ethernet adapter. (RTL8152/RTL8153)
    • Bug fixes and performance improvements.
    MYTVOnline Version 1.9.24
    • TV Series section added.
    • EPG downloading speed improved.
    • Fixed VOD playback issues with certain servers.
    • Long recording file playback issues fixed.
    • Fixed playback of multi-part recorded files larger than 4GB
    • Username/Password login issue fixed.
    • Empty Channel List - Server login issue fixed.
    • Added xtreamcodes API and M3u playlist support. (Work-in-progress)
    • Mapped keyboard F7 key to EPG.
    • Fixed UDP stream recording issue.
    • Fixed old HLS Startmode issue on Z7+.
    • Event reminders patched.
    • Various portal issues patched.
    New Language Support Added:
    • Polish - polszczyzna
    • Lithuanian - lietuvių kalba
    Translation Improved:
    • Russian - русский
    • French - Français
    formuler.tv
    Updates 25.01.2018
    • Formuler Z Series Firmware Version 2.8.0
    • MYTVOnline Version 1.9.6
    Update procedure:
    Release Notes:
    • Added new software download integrity checks (Very important for future Updates, more checks after download and trough update)
    • General bug fixes and performance improvements.
    • Fixed Channel search bug.
    • Fixed VOD search bug. Direct number input from RCU now accepted.
    • French - Français
    formuler.tv
    Updates 26.12.2017
    • Formuler Z Series Firmware Version 2.7.88
    • MYTVOnline Version 1.8.12
    Update procedure:
    Release Notes:
    • New Installer mode options
    • [lexicon]Settings[/lexicon] Lock, Apps lock, Channel List Style Setting. Contact your Formuler Sales rep to receive the new Installer Mode Template.
    formuler.tv
    Updates 29.11.2017
    • MYTVOnline Version 1.8.6.
    Update procedure:
    Release Notes:
    • EPG mode option added. Access from Menu - [lexicon]Settings[/lexicon] - EPG Data
    • Normal: Request EPG data with user timezone offset
    • UTC: Request EPG data with no offset (UTC 0)
    • Inactivity Standby Mode bug fixed
    • VOD UX and navigation improvements
    • VOD search UX improved
    www.formuler.tv
    Updates 08.11.2017
    • Firmware Z-Series Version 2.7.82
    • MYTVOnline Version 1.8.0
    Update procedure:
    Release Notes:
    • Screen-off mode added for faster recovery from standby mode.
    • Increased size of home screen mini-tiles
    • Faster wake-up from standby mode
    • Classic channel list UI style now available
    • Toggle from MYTVOnline >> [lexicon]Settings[/lexicon] >> Service: Select "Classic"
    • Fixed VOD title display bug
    www.formuler.tv
    Updates 29.09.2017
    • MYTVOnline Hotfix Release - v1.7.4
    Update procedure:
    • Please reboot your Z-Series device to receive the update.
    A hotfix for MYTVOnline will be released today to improve the performance of the new Channel Search feature.
    Channels can now be searched for by Channel Name regardless of the current channel group/category selected.
    Press the GREEN key to access the Channel Search Function.
    www.formuler.tv
    Updates 27.09.2017
    • Firmware Z-Series Version 2.7.76
    • MYTVOnline Version 1.7.0
    Update procedure:
    Release Notes:
    • Improved Turkish translation
    • Local Timeshifting enabled (Requires USB drive)
    • Pause, Rewind Live TV!
    • Advanced and powerful PVR trick modes for smooth fast-forwarding and reverse. 2x / 4x / 8x / 16x FF & REW speeds available.
    • Press the Play button on the RCU to show the time shift play bar.
    • Channel Search enabled
    • Press the GREEN hotkey to search for channels by Channel Name
    • Added DVB-T scan tables for UK and Ireland
    • Added Playback Limit function for service operators
    • Service Operators: Set the Playback Limit parameter on the server to Limit the duration of continuous playback for a single stream.
    • Save bandwidth, electricity, and prevent screen burn-in with this feature.
    • Fixed portal login issues with certain portals
    • Fixed incorrect stream playback issue when zapping channels on certain portals
    • Fixed subtitle display issue with certain streams
    • Improved UX for multi-depth VOD contents (Series/Season/Episodes/etc)
    • Improved Channel List and Info Bar UX
    • Improved grid EPG performance
    • Improved support for user-downloaded audio codecs.
    • Improved Russian translation
    Advanced USB PVR & TimeShifting
    Search for Channels by Name
    New Scan Tables for USB DVB-T tuner
    www.formuler.tv
    Updates 24.07.2017
    • Firmware Z-Series Version 2.7.70
    • MYTVOnline Version 1.6.0
    Update procedure:
    Release Notes:
    Formuler IPTV Firmware Version 2.7.70
    • Enabled background downloading of OTA firmware updates
    • Sleep function enabled
    • Press the sleep button on your RCU inside MYTVOnline or at the homescreen to toggle sleep interval
    • Z+ users, access the sleep function inside the MYTVOnline options menu (RED hotkey)
    • Added USB DVB-T2 tuner feature. (USB DVB-T2 tuner accessory sold separately)
    • Scheduled recording enabled. Access from single-channel program guide or grid EPG.
    • Various portal loading issues resolved
    • Added ability to cancel connection to portal mid-connection
    • Fixed channel list scrolling bug
    • USB Recording bug fixes and improvements
    • Remember VOD subtitle language preference
    • Fixed behavior of Play/Pause RCU button on Z+
    • Added manual subtitle encoding selection in options menu
    www.formuler.tv
    Updates 11.07.2017
    • Formuler Z-Series Version 2.7.62
    Update procedure:
    Release Notes:
    Formuler IPTV Firmware Version 2.7.62
    • Fixed compatibility issue with Skype App
    • Default launcher app banners now visible in the homescreen shortcut [lexicon]editor[/lexicon]
    • Improved image scanning performance in the homescreen shortcut [lexicon]editor[/lexicon]
    • Use the OK key to select APKs from the Auto APK Installer window (previously, only the RED key could be used).
    • HOME key now functions when on page 2 or 3 of the homescreen
    • Easy APK Deployment Tools Enabled
    A new automated STB configuration system has been developed for installers and system operators.
    ThisDeployment Tool allows installers and system operators/integrators to easily offer and deploy a custom STB configuration to end-users via an Android app (APK).
    When this APK is run by the end-user, it will automatically configure the STB with a pre-defined configuration. System look-and-feel, MYTVOnline Portal [lexicon]settings[/lexicon], and KODI can be auto-configured by the end-user with this new system.
    Request the Deployment Tools and documentation from your authorized Formuler sales rep.
    www.formuler.tv
    Updates 02.05.2017
    • Formuler Z-Series Version 2.7.50
    • MYTVOnline Version 1.5.0
    Update procedure:
    Release Notes:
    Formuler IPTV Firmware Version 2.7.50
    • Unified display of Date and Time formats throughout system and MYTVOnline
    • Installer mode: Supports up to 5 separate portals
    • Automated batch USB APK installation supported
    • Put multiple APKs into a folder named "apks" on USB root and insert into STB.
    • Added Soft Reset function to System menu for Retail and Installer modes
    • Clear System and MYTVOnline user data while preserving portal URLs.
    • Added ability to change the startup app from the System menu.
    • Black Screen issue fixed
    • Channel zapping speed improved
    • Fixed VOD subtitle loading issue with certain portals
    • Fixed issue in Catch-up EPG where past events after a certain time could not be displayed
    • Improved performance when setting event reminders
    • Improved performance and display of Grid EPG
    • Fixed crashing issue when loading certain VOD contents
    • Fixed VOD library loading issue with certain portals
    • Fixed VOD stuttering playback issue with certain contents
    • Added ability to change video aspect ratio with the V.Format button on the RCU
    • Added Complain feature when supported by the middleware
    • Press the RED hotkey to access.
    • Remote reboot and Remote reload portal supported from operator's dashboard.
    • Added external player option for VOD contents
    • Activate from MYTVOnline [lexicon]Settings[/lexicon] Menu.
    • Improved VOD series navigation
    • Press UP/DOWN to skip 10 episodes.
    • Simple USB Recording of live TV now supported
    • Press the REC button on the RCU once to begin recording.
    • Press REC again to show the recording dialog.
    • Press PLAYLIST to see recorded programs
    • General UI improvements
    www.formuler.tv
    Updates 07.02.2017
    • Formuler Z-Series Patch v2.7.30
    Update procedure:
    Release Notes:
    • Re-enabled USB APK installation
    www.formuler.tv
    Updates 06.02.2017
    • Formuler Z-Series Version 2.7.28
    • MYTVOnline Version 1.4.0
    Update procedure:
    Release Notes:
    Formuler IPTV Firmware Version 2.7.28
    • Fixed issue where certain installed apps disappeared after reboot
    • Fixed issue where app shortcut would disappear after upgrading the app
    • Improved group/page navigation in Launcher UX
    • Improved appearance of group edit icons in Launcher
    • Added ability to connect to user-defined app markets
    • Installer Mode: Enable/Disable Play Store
    • Installer Mode: Enable/Disable MYTVOnline autostart
    • Fixed event information not displayed when zapping with the CH UP/DN buttons on the RCU
    • Fixed freezing issue when switching between portals
    • Fixed audio sync issue when switching audio tracks
    • Fixed VOD playback on certain services
    • Fixed VOD subtitle display for external subtitle files
    • Improved Info Banner design - Better layout and more information displayed
    • Larger Channel Name, Now/Next Event displayed, Buffer Health, and more.
    • Improved channel icon image quality
    • Added A/V Buffering time control. Access from [lexicon]Settings[/lexicon] >> Buffer Time
    • This setting controls the amount of time taken when buffering from an underrun condition.
    • Added advanced channel recall list
    • Press BACK on the RCU to recall last channel/Hold BACK to view the channel history list.
    • Added TV event reminder and alarm feature
    • Access from the single EPG or the grid EPG.
    • Added detailed info box to Live TV
    • Press INFO button twice to display detailed event information (when available from the server).
    • Added VOD Filter & Sorting. Filter by First Letter, Genre, Year
    • General stability and speed enhancements
    • User interface improvements
    • Portuguese - Português (Portugal)
    www.formuler.tv
    Info 05.02.2017
    Formuler IPTV Name Change
    In an effort to provide easier product identification and differentiation with the F-series product line, Formuler IPTV has been renamed to Formuler Z Prime.
    Formuler IP/OTT products will be categorized with the Z branding.
    Formuler DVB products will remain in the current F-series category.
    Updates 13.12.2016
    • Formuler IPTV Firmware Version 2.7.14
    Update procedure:
    • Please reboot your STB to receive the update!
    Release Notes:
    • Fixed issue with on-screen keyboard not showing colon key in some apps
    • Added Enter key to default system keyboard
    • Improved system keyboard layout
    • Fixed player issue with certain streams and 3rd party apps
    • Faster task switching between MYTVOnline and other apps. Less reconnections and less load on the server
    • Russian, Dutch, Turkish language translation improvements
    • Launcher UI/UX improvements
    • Added new system apps: APK Installer and Web Browser. Apps can now be installed from USB when device is not locked down
    • Screenshot feature added - Press and hold the REC button to save a screenshot to USB
    • Http image links allowed in iptvconfig
    • German - Deutsch
    www.formuler.tv
    Updates 12.12.2016
    • MYTVOnline Version 1.3.0
    Update procedure:
    Release Notes:
    • Full support for HTTPS portals
    • Group channel numbering option added to [lexicon]settings[/lexicon] menu. When "ON" every group channel number starts at 1
    • Channel name and icon are now displayed when playing back catch-up contents
    • Added ability to clear user preferences in [lexicon]Settings[/lexicon] menu
    • Shortcut keys added. Use F1, F2, F3 buttons on the RCU to directly access Live TV, VOD, and Radio
    • Channel icon display bug fixed
    • Background image bug fixed when installer mode is applied
    Updates 31.10.2016
    • Formuler IPTV Firmware Version 2.7.8
    • MYTVOnline Version 1.2.0
    Update procedure:
    Release Notes:
    • Home screen (Launcher) updated. Users can now customize the app tiles and add up to 3 more app groups. (Long press OK on any existing tile to bring up the customization menu)
    • Page UP/DOWN scolling function available in mouse cursor mode. Use the CH UP/DN buttons in cursor mode
    • Various minor UI improvements
    • Power LED behavior improved
    • App icons quality in All Apps menu improved
    • molcfg encryption now available. Contact your Formuler rep for details.
    • System popup window color can now be defined via iptvconfig file. Contact your Formuler rep for details.
    • Radio Channels Added to Main Menu
    • EPG optimizations - General
    • New Single-Channel EPG. Access by pressing Right Arrow on the RCU at Info-Bar or Channel List.
    • Favorite channels now saved on the server. Favorites will survive factory reset.
    • Parental PIN now saved on the server. PIN will survive factory reset.
    • Subscription Expiration Date now displayed in [lexicon]Settings[/lexicon] menu
    • VOD User Interface overhaul
    • VOD Search function added
    • VOD details added: Rating, Genre, Actors
    • Fixed various issues when switching between portals
    • Stability Improvements
    • Installer Mode : Added backup portal to configuration file. Contact your Formuler rep for details.
    • molcfg can now be pushed from server dashboard. Contact your Formuler rep for details.
    • Nederlands - Dutch
    • русский - Russian
    • Türkçe - Turkish
    • Hrvatski - Croatian
    Updates 10.10.2016
    • New MYTV Online updated to version 1.1.2
    Update procedure:
    Release Notes:
    • App startup issue resolved
    Updates 23.09.2016
    • New MYTV Online updated to version 1.1.0
    Update procedure:
    Release Notes:
    • Catch up TV : Single Channel 1-day List EPG added (press the yellow button in the EPG)
    • Messages sent from server are now displayed in a popup window
    • EPG optimizations
    • GUI List animations added for smoother appearance
    • GUI optimizations - general
    • Portal connection issues resolved
    • Added hotkeys for grid EPG navigation. +/- 1 day, Go to current event
    • Audio playback issue for certain media contents resolved
    • Channel List font size adjusted.
    • Fixed OSD issue when using mouse navigation
    • Minor Bug fixes and performance enhancements
    292-clip-image002-png 293-clip-image004-png
    Updates 06.09.2016
    • New Firmware update 2.7.0 for Formuler IPTV Box.
    Update procedure:
    Release Notes:
    • Google Play Services and Play Store added
    • Minor improvements and optimizations
    Updates 11.08.2016
    • New Firmware update 2.6.2 for Formuler IPTV Box.
    • MYTV Online updated to version 1.0.2
    Update procedure:
    Release Notes:
    Formuler IPTV Firmware v2.6.2
    • New custom market framework for Installers implemented
    • Power-down mode names changed to be more intuitive
    • RCU Home key working in all sub menus
    • Ethernet menu >> 'Connected to Internet' test is properly implemented
    • Default System keyboard Caps Lock issue fixed
    • RCU mouse pointer movement smoother
    • Various other minor fixes and improvements
    MYTVOnline v1.00.02
    • Catch-up TV is now available through the EPG interface
    • Subtitle and Audio Track selection available in VOD and LiveTV modes
    • EPG display issues resolved for most servers
    • VOD TV Series playback issue resolved
    • VOD jump interval now adjustable via Options popup
    • RCU Media playback buttons functioning in VOD mode
    • Adult channel group display issue resolved
    • Various portal connection issues resolved
    Updates 07.07.2016
    • New Firmware update 2.6.0. rev 5746 for Formuler IPTV Box.
    • MYTV Online was also updated to version 0.9.03.
    Update procedure:
    • Please reboot your STB first to receive the update!
    Important notice:
    • v2.3.1 → v2.6.0 forced factory reset (must be done)!
    • v2.4.0 → v2.6.0 factory reset NOT required
    • v2.5.0 → v2.6.0 factory reset NOT required
    • v2.6.0 → Future versions, factory reset NOT required
    Pin Code for factory reset:
    • 0000 (4x Zero)
    Release Notes:
    • Installer mode added.
    • EZ STB setup and branding via configuration file
    • Removed all Formuler branding from Installer Mode
    • Parental Controls added.
    • PIN protection added to System [lexicon]settings[/lexicon] and All apps
    • Animation effects added to menus with long item lists.
    • Ex. System Language
    • Booting animation changed
    • Default standby mode changed to Smart Mode. Users can change this option from the System Info menu
    • MYTV Online starts automatically after waking up from Smart Standby Mode
    • MX player and KODI now start automatically after downloading for the first time
    • Power LED issue fixed when in Smart Standby Mode
    • Fixed software version rechecking issue after exiting from system [lexicon]settings[/lexicon]
    • Fixed issue where TV audio still playing after exiting from MYTV Online
    • Fixed software version display issue after system update
    • General UI/UX improvements
  • Empfehlung an Käufer!
    Bitte sofort nach dem anschließen und kurzem Einstellen, ein Reboot machen (falls keine Update-Meldung erscheint) und das Angebotene Update auf Version 2.6.0 durchführen. Nach dem Update unbedingt ein Reset durchführen (Werkseinstellungen laden), erneut die Einstellungen durchführen, anschließend kann die IPTV Box weiter benutzt werden.
    Pin Code für das laden der Werkseinstellungen ist : 0000 (vier mal die Null)
    Kodi Info: Zum jetzigen Zeitpunkt steht noch Kodi 15.2 zur Installation bereit. Bis ende des Monats wird diese mit der Aktuellen 16.1 ausgetauscht, nachdem Market erneuert und Aktualisiert wurde. Nur als Info um sich doppelte Arbeit zu sparen.
    - SPMC 16.3 wurde bereits heute ins Market eingebunden.
  • Update...
    Firmware rev. (07.02.2017):
    Release Notes!
    A minor patch for Formuler Z-Series products was released today for users experiencing problems with USB app installation.
  • Update...
    Firmware rev. (02.05.2017):
    Release Notes!
    Many optimizations and new features are available with this release.
  • Next week comes new Firmware for Z-Series.
    System Firmware Release Notes:
    MYTVOnline Release Notes:
  • New Update...
    Updated Models: Formuler Z Prime / Formuler Z+ / Formuler Z
    • Firmware Version: 2.7.76
    • MYTVOnline Version: 1.7.0
    The long awaited Formuler Z-Series September update has been released over the network for all users.
    Proving again the dominance of the Formuler system solution, we have integrated advanced USB PVR and TimeShifting into MYTVOnline.
    Users can now pause and rewind Live TV! The unique Formuler solution allows for smooth Fast-Forwarding as well as up-to 16x Fast-Forward & Rewind speeds. Replay your favorite moments at-will.
    Use the PVR buttons on your RCU to use the new TimeShift functions.
    Be on the lookout for slow-motion playback in the next Formuler Z-Series update.
    Reboot your device now to receive the automatic OTA updates.
    Release Notes
  • New Update...
    Updated Models: Formuler Z Prime / Formuler Z / Formuler Z+
    Reboot your device to receive the automatic OTA update.
    Firmware release notes:
    • Z7+ : Added new wifi drivers (RTL8811AU, RTL8812BU)
    • Z7+ : Fixed Miracast standby mode bug
    • Z7+ : Youtube 2.0 available now. Enjoy 4K Youtube contents on your 4K TV.
    • Z7+ : General bug fixes and stability improvements
    MYTVOnline release notes:
  • New Firmware for Z Series is now out. Reboot your device to receive the automatic OTA update
    • Firmware Version: 2.7.82
    • MYTVOnline Version: 1.8.0
    The November Z-Series software update has been released and is ready for immediate download.
    The MYTVOnline v1.8.0 update gives users to option to switch to a more traditional channel list layout (P.I.G. Service List).
    Access the new option from the MYTVOnline [lexicon]Settings[/lexicon] menu.
    Formuler has also implemented the "Instant-ON" technology to save time when powering-on the box from standby mode. Wake-up time from standby has been drastically reduced.
    Release Notes
  • MYTVOnline has been updated to version 1.8.6.
    Minor refinements and fixes are available in this release.
    Updated Models : Formuler Z Prime / Formuler Z+ / Formuler Z
    This update will be rolled out to Z nano and S-series models in the coming week.
    Release Notes:
  • The December Z-Series software update has been released and is ready for immediate download.
    MYTVOnline v1.8.12 provides on-screen help for choosing the preferred channel list style. Users can always change the style option from the MYTVOnline [lexicon]Settings[/lexicon] menu at anytime.
    Formuler has also implemented more options for installers to give finer control over the user experience. Contact your Formuler Sales rep to receive the latest Installer Mode Template.
    Updates 26.12.2017
  • Updates 25.01.2018
    Release Notes:
    • French - Français
  • Info:
    New Beta is out and the Beta Tester Groups are checking the new Firmware and MYTVOnline now.
    Official release will occur after the software has been thoroughly tested.
    Info FW and MYTVOnline:
    • Formuler Z, Z+, Z Prime firmware v2.8.5
    • MYTVOnline v1.9.11
    Below are the major fixes and areas that should be tested first, before the OTA starts:
    • MOL: EPG downloading speed improved
    • MOL: VOD playback issue with certain servers
    • MOL: Z7+ timeshift playback performance improved
    • MOL: Long Recording playback issues fixed. (Split file playback issue)
    • MOL: Username/Password login issue fixed.
    • MOL: Empty Channel List - Server login issue fixed.
    • MOL: Added xtreamcodes API and M3u playlist support
    • MOL: Mapped keyboard F7 key to EPG
    • MOL: Fixed UDP stream recording issue
    • Added support for USB3.0 Gigabit Ethernet adapter. (RTL8152/RTL8153). amazon.com/Anker-Portable-Ethe…k-Notebooks/dp/B014ZOJX7W
    Full release notes will be available later today. Please check this post/thread again. Thank You for your patience
