Hi guys has anyone got instructions on how to set up the new remote that’s coming out thanks
Bt1 remote set up instructions
On the packet
SAM
Moved the thread from forum General about Formuler Z8 to forum GTV-BT1. -
Here you can find the how to for BT1 -> BT1 set up instruction
Can anyone find AV button or isn't there one . I frequently flick between E2 and Z8 devices attached to TV
What do you want av for mate
Av on Vu+ / Source on Formuler, to change from one device to another on TV It's on other remote and every remote i own
Source button bottom right try that mate
Did you find the a/v button mate
Cheers no specs and when i looked at button description just thought they were programmable. Works in IR TV mode, Powers up TV from standby aswell I thought it was odd not being one
.Should have gone to specsavers instead of select specs
Cheers M8
I follow the instructions for pairing the remote in bluetooth.
I still Ok until the step 4 where i got the Mac adress of the GTV RCU but i don't reached the last step 5 where it's indicated "paired".
On the step 4, the white led blink and after a while stop blinking and nothing happen's.Could you help me...?
Merci
Merci
Press "OK" on the remote when you see the Formuler GTV RCU listed in the Bluetooth search list.
Thanks for the answer but i did it and it doesn't work ...
It works now...
I tried pairing with my smartphone and i did it after with my Z8 and finally, it works.....!
I need help. My dog sat on my GTV remote and now it won't work with the GTV. Ive tried all the video and nothing helps. Now the screen is saying An error occurred: invalid Response CodeException. How can I pair the remote back again with the GTV? I have an iPhone, not Android phone btw
even if it is unpaired from BT mode, it should still control the GTV via IR mode (orange led), reboot your gtv, then go to BT settings and repair it..
I tried rebooting but when it comes back up, the remote won't move to LET me get to BT settings.
Take batteries out and leave a while then try again.
Press OK + Menu button until the led changes and you see white led flashing. Try then to pair.
