MYTV has gone down, been in touch with the provider they said ALL OK should be working but isn't.
Not had this problem before, done all the usual stuff.
Check internet connection ( rebooted ) turned on & off Z8 box, but still not working.
I only did a total Factory reset a few weeks ago for some other reason.
Do I need to keep my VPN on or can I use without will it be SAFE...
Cheers in advance for your HELP...
Popeye05...
