Seems that every time the SD card reaches its max capacity, it stops to record and the rewind, pause features no longer work unless I remove the sd card, format on my computer then reinsert into the formuler.
Is there a way to make the Formuler loop the recordings so that it overrides its previous recording so I don’t have to keep pulling out the card, format and then reinsert into the box?
