New official update Hotfix released for Z8 / Z Alpha.
WARNING:
The install process and reboot works automatically! Please don`t turn off the box or unplug the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
Firmware Version : 1.4.73 HOTFIX
- ADD: Force HDCP 1.4 mode menu
- Android Settings > Advanced Options > HDMI CEC, HDCP
- FIX: Automatic System Date & Time bug
- IMP: System memory optimization
MYTVOnline 2 : 7.9.3 HOTFIX
- ADD: Online subtitle search languages: Suomi, Dansk
- FIX: EPG Loading issue
- FIX: Channel number search issue
- FIX: Re-enable Cloud TimeShift from Normal Channel list
- FIX: VOD Trailer button not shown under certain circumstances
- IMP: Swedish menu translation
