New beta released for Z prime <> Z7+5G.
Beta Firmware Version : 1.3.1 for Zx, Z7+, Zx 5G and Z7+ 5G
Beta Firmware Version : 2.9.1 for Z prime, Z, Z+, Z Nano
Beta MYTVOnline : 2.0.1
WARNING:
HowTo Install:
Home Menu ->Cog. Wheel -> Software Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
Beta FW 2.9.1or 1.3.1 - SW 2.0.1 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
Change Log
Firmware Version : 2.9.1/1.3.1 BETA
Fixes & Improvements:
- FIX: Certain apps can't be started from the home screen
- FIX: Automatic System Date & Time bug
- FIX: Android Settings > Languages & input > Virtual keyboard > RCU d-pad keys not working
MYTVOnline : 2.0.1 BETA
- ADD: Main Menu > Recordings, Exit menu items
- ADD: Main Menu > Settings > EPG All: On/Off. Choose to download the All EPG package or not
- IMP: Press and HOLD PLAY to start Cloud Timeshift. No need to press INFO button
- FIX: Problem connecting to HTTPS portal
- FIX: Long loading times for VOD and Series sections
- FIX: Problem with some m3u and xmltv URLs
- FIX: Can't view VOD > All group
- FIX: VOD Player > subtitle end-time issue
