Hi, what is the difference between the 2? what do I loose if I do one instead of the other? Thanks
factory reset and software reset
- Hardware
- Z7+ 5G
- fireneg
This article may answer your question,
Official Formuler S and Z - Series Factory Reset Tool and how to'
How to do factory data reset on Z8 from Home Menu.
Factory Reset after firmware 1.2.71 and newer
Its ok for factory reset but what about software reset? Thanks
Good night.
I'm trying to reset my formuler z+ via usb but after inserting the _recovery_facinit file on the pen drive and putting it on the device, the image is always loading and that's it. I would like to know how I can do an effective factory reset because the box is always blinking both green lights at the same time and even after following the steps in the _recovery_facinit file I can't solve it because the image doesn't come out of the loading and keeps blinking for indefinitely the green and red lights and does not advance from loading. What is the solution to be able to finish the reset and recover the box? Thanks
Good night.
Did you press the Channel up key successively while booting?
of course yes. I did all this and then the image with the name formuler appears, but then it just appears loading and it doesn't go beyond that.
Try this way -> Factory Reset after firmware 1.2.71 and newer
It worked. I managed to get the box back. Thanks a lot for the support.
Good afternoon
My formula z+ box stopped working again but now the problem seems different because when I turn on the box it has the two green lights on continuously and without blinking.
I already tried to do the reset process again through the USB mode and also through the mode that the administrator Sam told me in the last conversation and none of that worked.
I would therefore like to know if there is a way to reset this new problem because the green lights are always in the same position and the box does not react to any of the methods I explained earlier. I am waiting for someone to be able to help me in this situation. Thank you very much
Seems its time for new Z11
Cut the power for 5-10 Minutes and try again.
It still doesn't work. I already have a formuler z8 that I use on another tv and I would like to recover this formuler z+ because it works for the second tv. Is there another way to solve the problem?
Disconnect usb device from the box and try again, if same, try factory reset like last time. If that not helps then is some hardware failure the reason. It is hard to say why this errors happens on your box, it could be bootloader but also something else on motherboard.
