I have a reseller who is not able to put my mac and he says it's already used.
Is there a way to change the mac id of MOL2?
Thank you
Thank you
No. Use m3u instead.
I expect you already know this, but the mac address you need to give is not the one that says mac address on the box, it's the SN that starts 00:1A that you have to give.
ID 00:1A:79 not SN.
Yes I mean the mac ID. It would be nice if the developer provide the possibility to change it. Example: he can put a restriction like not to change this mac id more than 2 times per year
Is not possible, MOL2 on your box have always same ID. If you would be able to change the MAC/ID you will have conflict with other user with the uniq ID he have on his box. You can imagine what would happen if thousands of users frequently change his ID´s. Is not good for him, provider or you.
Like Mevi suggested, use XC Api Portal (without need for registering the ID) and you will have more options than stalker with MAC/ID in Portal. M3U Playlist of course too, but with less options.
Why would you want to change your mac id? One is not enough? You should be carefull to who you provide your mac address and not giving it out randomly to all providers/resellers. Every device has it's own unique mac address, being able to change it would lead into abuse.
There is a reason to change the MAC address: I also have a Infomir box in another apartment, so that I can use the same line I also have to be able to use the same MAC address.
This most likely won't work since the 2 boxes will have different device_id, device_id2, signature, etc, and unlike stbemu, you can't change these values in MOL2.
