OpenSPA 6.0 releases
  • OPENSPA 6.0.005
    What is new
    - OpenSPA installation images using Flash Online. It is a completely online method without PC. Notice : if you install any previous release to 6.0.005, when image starts FlashOnline will not be available.
    - Improvements in spanewfirm (Installation Wizard OpenSPA), now it's compatible with FlashOnline.
    - Improvements in spaMetrixJR, now you can also configure OpenSPA menu icons.
    - Added secondinfobar screen with extended information in MetrixJR.
    - Improved EPG Movistar +.
    - Improvements in spzImdb, to make finding films information easier and faster .
    - Improvements in OpenSPA downloads module.
    - Fix TV series recording plugin for channels with name changed.
    User : root
    Password : openspa
    Note : Online update not available
    Download
    Einmal editiert, zuletzt von sergiri ()
  • OPENSPA 6.0.006
    What is new
    - FlashOnline improvements to use every mounted device (pendrive, hdd, microSD, etc.). Network mounts can't be used
    - Improvements in spanewfirm (Installation Wizard OpenSPA), now it's also compatible with multidevices.
    - Changes in Confluence and MetrixJR skins.
    - Added stream port [lexicon]settings[/lexicon] and stream authentication for more security in spzremotechannels
    - Added new M+ equivalences
    User : root
    Pass : openspa
    DOWNLOAD
  • OPENSPA 6.0.010
    What is new
    - New drivers [email protected] HD51
    - New drivers Vuplus Solo 4K, Solo2, Duo2 and Solo SE
    - Fix standby to stop tuners when box goes to standby.
    - Improvement in series TV recordings.
    - SpaNewFirms: Added option to leave skin you have in previous release
    - New Panel Extra OpenSPA, where you can do :
    • Download channel lists uploaded to our forum.
    • Download updated mhw_EQUIV.epg file.
    • Download satellites.xml, port.list, cccam.channelinfo,...
    • Look at hardware and software info
    - Added new options for skin MetrixJR
    • Added turquoise color
    • Added new infobar with information about transponder and bitrate in same infobar
    • Added new infobar to use with transparent zzpicons.
    - Minor fixes.
    User : root
    Pass : openspa
    DOWNLOAD
