I have been using Formuler Z8 about a year. I never had any problems with the Formuler Z8. I have been waiting for new Formuler box but when i bought it on 27th November i have been experiencing problems with :
1. Seed4me VPN (2.08) app. i have an account l log in ( about every 10 second i get Disconnected Automaticly when i choose country for connection ( every country ) . even when the location permission is on still get disconnected. i have restored the box and installed first seed4me but still get disconnected. because i couldn't use seed4me properly i installed Nord VPN the last version i cannot connect even when i changed some settings VPN protocol OpenVPN(TCP) when i do that i can connect only once the second time i can't get connected.
2. Teamviewer QuickSupport last version. when i open it i can't remote it from the pc (only file transfer and look at the screen ) when i open the app i get popup(add-on available This device supports our Remote Control feature. In order to use this feature, please download our free Add-On. Cancel or Download. when i click Download i get New Window with THIS IS NO STAND-ALONE APP Please do not download this app by itself. On supported devices, this add-on will be available through other apps automatically. under this text i see ( Your device isn't compatible with this version.
3. Total Commander. when i want to transfer a file from Formuler GTV to Usb i get popup with Write error. Error writing to target file!
4. Google Play Store. i can not find some apps that i'm looking for when i was using Formuler Z8 i could find them.
When i was using Formuler Z8 i never got these 4 problems when i got the New Formuler GTV becouse is faster and newer i never thought that i will get any problems. but seems like the new Formuler GTV gives more problems with the apps.
