For the last year I used NordVPN app. It worked fantastic. For some reason it stops working. I'm getting the error "invalid credentials" (YES, I'm sure they are correct). (I can log in with the same credentials on another Z Nano, on a Z 7+ and on a Z8).
I found that the problem is due to NordVPN app version. My Z Nano has "App version 3.4.3+sideload" of NordVPN just after a successful manual factory reset, followed by an automatically (and mandatory) firmware update. But NordVPN still not connecting.
A relative of mine owns a Z Nano, that has "App version 3.13.3+sideload" of NordVPN installed and is working flawless using the same credentials.
Nobody touched that box. I'm the only one who supports him with Z Nano box. Why it has a different version of the one I own?
If, somehow, it was updated, why mine doesn't do the same update?
Does Formuler firmware updates include android apps update?
I know we can't install apps other than the ones that are on the ZNano's minimarket.
But, it must there be a way to update to the same version of my relative's Z Nano ("App version 3.13.3+sideload"). Somehow it happened on that box. That's a fact. Don't you agree?
Can you help me?
Thank You
