H.265 Hevc (Important!!)
  • For all Formuler IPTV / Z Prime users,
    I have tested multiple "MKV-files" with different "H.265 HEVC" codecs (also know as 4k / UHD movies) and they all failed to play. Just to let you all know, that the media player capabilities of this device are not what you expect them to be. The formuler IPTV box is unfortunately not capable of playing these types of files!
    Best advices given by the their official formuler support is to buy the next Formuler IPTV Box!
    example file:
    Format : Matroska
    Format version : Version 4 / Version 2
    Overall bit rate : 69.8 Mbps
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Codec ID : V_MPEGH/ISO/HEVC
    Duration : 2h 23mn
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Multiple Audio options: AC-3 & DTS
