Its been going on for a while. anytime you are watching VOD and it works fine. However if you happen to pause video at any point and replay after few minutes VOD always stops and you have to replay from start.
VOD stops if you pause video for any reason at any point
- MYTVOnline2
- Z8 Pro
- md66
I Checked with the 2 different connections, and there wasn't the same issue with you.
it could be the your providers problem.
So don't pause it
Just keep repeating, "I'm not paying $200 a month..."
It's not only when you pause. It seems it happens all the time now.
That was helpful
So don't pause it
Wow Mevi, you found the solution.
When the video stops and you repeat again, is the time code not set (Red line)? I guess you use XC Api as protocol?
Try to reinstall MOL2 and check if fw and sw are updated to last version on your box.
Had it happen to me once, but just paused for 10 minutes and started right up. Could it be a provider thing, where they terminate the connection if idle?
Don`t think so, then would also Live TV not work. Except 3h Playtime limit on Stalker MAC/ID but i guess this is not the case.
He can also recheck with other app.
We are having the same issue here as well.
Pause VOD, unpause, crash.
Please make video from your Z8 pro and upload to streamable, in video record at least two vod starts, pause and playback + crash. Thx.
Possibly not the same issue, but I have seen similar happen with regular timeshift. For example, I change to a channel, a new timeshift file starts, and after a half hour or so if I pause for say 5-10 minutes and return, when unpaused it will start at the beginning of the timeshift file rather than where it was paused. Not a show-stopper and not easily repeatable.
Sorry, we have a GTV not Z8. Plus, no idea how to...make video from your Z8 pro and upload to streamable, in video record at least two vod starts, pause and playback + crash
Please don`t mix z8 and GTV threads, this are fully different boxes, OS and MOL2 version.
With handy and https://streamable.com/ (register free) , upload your video and post link to your video.
There is another thread like this where VOD stops at 80% shows the show wad fully watched and if its a series jumps to the the next one. still looking for a fix.
