Live recording consistently stops after recording just one minute (or a bit less). Scheduled recording works fine. Can you suggest how I can get Live recording to work consistently? Thanks.
GTV & Tivimate - Live Recording stops after 1 minute
- Help
- GTV
muralin -
October 17, 2021 at 6:25 PM -
Try to format with this tool on your pc and your usb stick with ntfs.
And this happens with Tivimate on GTV? Please give me more detailed info, because i`m at moment tracking GTV recording and collect all error infos with GTV recording. No matter if MOL2 or other apps.
Tivimate: Yes. I was unable to record a live stream. Recordings stop after a minute. No issues recording scheduled events. I changed my subscription from one device (connection) to two and the problem went away. Now I can record live as well as scheduled recording and store them in a USB stick with no issues.
MOL2: Cant record anything. Always get the message Recording error. I have tried all the suggestions such as format the stick with Rufus, etc. No change - cant record anything.
For now, I have decided to stick with Tivimate even though I am more comfortable with MOL2 UI/UX.
And the used USB Stick is only once formatted with Rufus, connected with box, box rebooted and set then in MOL2 menu as recording device? Please do not format with the box again, only with pc and ignore the flash message from box in home menu.
Sam: Followed your instructions. Now MOL2 crashes immediately after opening. I went back to the factory installed version and that also crashes immediately. When I try to update to the latest version of MOL2, I get IPTV Download error. Tivimate continues to work fine. I am trying to avoid going back to GTV's Factory settings. Let me search the forum to figure out how to deal with MOL2 crashing immediately after opening.
Reinstall Mol2 and try to install latest version again that is in sync with your firmware.
I uninstalled and reinstalled the factory installed version. That crashes after playing less than one second of the video. Get IPTV Download error when I try to update MOL2 To the latest version.
