i need offline firmware of formuler z prime
  • hello i have installed in my formuler z prime a firmware i found it in the net from company who works with formuler
    i need to return to my original firmware
    please help me
    thanks in advance
  • I don`t know what you really installed on your box and from what of kind company, but we don`t have Prime z firmware! Firmware updates comes from Formuler server directly.
    What you can do is factory reseat and look if it works like before.
    Do you have the link to this file and company?
  • yes i have a link to this copmany the file that i need it is the config file molcfg.enc
    i think is not the firmware i do mistake sorry
    the site of this company is icone.bz
    thanks
    the reset does not work for me
    thanks
    Hello. Your box may be locked to the Icone service.
    Navigate to Home >> [lexicon]Settings[/lexicon] (gear icon) >> System >> Factory Reset
    If you do not see the Factory Reset option, contact Icone for the unlocking instructions.
