iptvluncher not responding
  • hi im trying to setup my formuler z but keeping getting iptvlauncher not responding, wait or ok. none of both options do anything, and thats it, no menu appearing when i press exit or menu. nothing! any help plz
  • Attached is the USB recovery tool and instructions.
    That address the booting issue after the last Z-Series update.
    #. Formuler Z Series Recovery tool instructions
    Affected models:
    Formuler Z Prime
    Formuler Z+
    Formuler Z
    Applicable Software version:
    July 2017 Firmware 2.7.70
    Symptoms:
    After updating to Firmware 2.7.70, the set does not boot to the homescreen.
    Black screen is shown and the following message appears on screen:
    "IPTVLauncher isn't responding."
    Recovery Instructions:
    1. Extract update.ird from the ZIP archive to USB root. Make sure update.ird is the only file on the USB.
    2. Insert USB into Formuler Z device.
    3. Remove power cord from Formuler Z device.
    4. Insert power cord while repeatedly pressing the CH UP button on the RCU until the "Installing system update..." message appears on-screen.
    5. Set is repaired and user [lexicon]settings[/lexicon] remain unmodified.
