Sleep after inactivity
  • Hi!
    Just bought a Z prime.
    On most TV's there is a feature that makes the TV go to sleep after choosen time of inactivity, every time its on.
    I did find a sleep timer on Z prime but its just for one time, and not an inactivity sleeper..
    Is there a feature that will make the box go to sleep after inactivity?
    BR/Bambatant
  • Hello, your feature request has been forwarded to Formuler R&D for consideration in the next software update.
  • Is there a way to deactivate the user inactivity option?
    I need to leave the box running for several hours without interaction and the box shuts down after a few hours.
    That setting is currently controlled by the middleware (i.e. your service provider)
    Contact them if you have further doubts.
    We will soon add a new option for users to control the inactivity standby timer duration when this property is NOT set in the middleware.
