Hello, i just bought a z10 pro max, which i'm verry happy with. I've got the latest updates on it.
I was testing for the first time MyTVOnline2 and when I go on channels in FULL HD (and only those in FULL HD) I have NO sound at all, but i have the normal system sounds.
On the other basic "HD" channels, I have normal sound.
At some point I get a message telling me Ineed to install new codecs to make these channels work correctly.
I accept and it installs "Audio optimizer" I then reboot => I now have sound on all channels! But now.... the image is EXTREMELY jerky as if it was at 5 FPS but the sound worked fine. (on youtube and mytv, not on the normal interface of the formuler, it's jerky just when playing content)
I went to the image settings and it was set to : Auto - 1080p 60HZ, I decreased to put on 50HZ, rebooted, and then the picture and sound work fine !
Can someone please explain to me if I did it right? And why I needed to install new codecs? Is it normal? (the problem is solved but i'd like to know what happened and if i solved it in the right way.)
Thanks in advance
