My fellow users, Formuler Z10 Pro Max.
We have bought 3x Z10 Pro Max.
Within a period of 4 months.
All boxes have been installed automatiq with the latest firmware.
Now i have updated all 3 boxes to MYTVonline V10.10.35
The problems started, all sorts of connection failures rises.
- Server Error HTTP401
- Server Error HTTP999
- Server Error HTTP502
And not to forget, the box, used to connect within 20 seconds to TV, VOD, and Series
After update at least 180 seconds, and not even that good.
I tried my box somewhere else, same problems.
Tried 3 different ISP. Same problems
Full hardware reset, by HARDreset, no sollution.
I even bought a different IPTV Connection for 6 months, same problems.
I did internet ping test. I have a gigabit connection, 820 MB Download.
I even changed the router and the switch no sollution.
I have had contact to service center NL, and they confirmed that the Formuler Z10 Pro Max has a issues by loading time 19.000 channels.
I asked if the IPTV could be reduced to several NL Channels, loading time is now 15 seconds.
I have still above mentioned problems.
At last i used my old Amiko 6N Box. No problems at all.
Does somebody has the knowledge to solve my problem, or has the same issue.
Maybe by this way there will be a forged sollution.
I there a update available to solve my problems?
