BETA Software Update for Formuler Z10 Series devices.
Firmware: 10.10.39 BETA
MYTVOnline 2 : 10.10.35 BETA
WARNING:
HowTo Install:
BETA FW 10.10.39 + MOL2. 10.10.38 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
Change Log
Firmware Version : 10.10.39 BETA
- NEW: Add external storage format changer
- NEW: Add support for WPA3 security protocol
- NEW: Add USB tuner support for Xbox One Digital TV Tuner (DVB-T)
- FIX: Launcher crash loop
- FIX: Bluetooth paring bug when incoming connections are restricted
- FIX: Unable to switch on Wi-Fi after installing firmware 10.10.36
- FIX: Unable to scan DVB-T2 channels
- IMP: Change default storage type for recording
MYTVOnline 2 : 10.10.38 BETA
- FIX: Channels missing randomly
- FIX: Menu key not responding on the first connection
- FIX: "No information" in M3U playlist EPG
- FIX: Moves to home screen after sorting channels
