OTA Update
  • Since last update 29 September mytv became unresponsive. Basically it took me like 30 attempts to get the round grey circle to work. I had to reset the box and after another attempts the image worked. Now everytime I change channel the menu freezes not allowing me to change channels. The first channel might work but if you try to change anything the entire thing blocks. Then two messages appear first mytv app became unresponsive do you want to close it? And after that one iptv launcher became unresponsive do you want to close it? I have to mention that no function whatsoever works at this point I have to unplug the cable from the box so that it will reboot. Even though I get the shut down restart menu when pressed nothing happens. Anyone has the same problems?
