Discussion thread about new Z11 Series.
Questions about Formuler Z11 Pro MAX, Z11 Pro and MOL3.
- Z11 Series
- SAM
I like the specs of Z11 pro and would love to see the myonline 3.
Just hoping Formuler would consider implementing the new myonline 3 on GTV and Z10 series.
I know it's early software but ive seen that you now can schedule update of epg and data from provider.
Epg is down to every 3h, and channel data once per day on selected time. It would be good to have channel data updated more frequently like the epg choices? As providers update their lists several times a day
which dolby audio is supportert?
Does anyone know if Mol3 gives you access to all services at the same time rather than having to come out of a service and switch to another.
This for me would be the single biggest improvement they could make and I'd definately be purchasing if it had this functionality
Love Mol2 but find myself using other apps because I want the ability to watch one service and record from another or when I search for something it return the results from all services rather than 1 service
Love Mol2 but find myself using other apps because I want the ability to watch one service and record from another or when I search for something it return the results from all services rather than 1 serviceYes and you are always connected to all active subs/lines, no need to connect again.
Hi I have few questions regarding MOL3
1.
can I use catchup from an m3u from editors ilike xtream editor/ Iptv boss?
2. Can I still use the classic I think it's called "classic style" guide?
3. The site I normally buy off has told me the pro max is €170 which seems a bit extreme so just wondering if there's a cheaper alternative for Eu ?
Just a quick question for when the Z11 arrives.
Same installation as Z10? Also needs the Audio Optimizer i guess?
Just a little different but very intuitiv, audio optimizer is again on board.
Notification system is nice.
Just need to be tweaked a bit.
For example right now with auto update on content active.
You still have to manually go into the content menu, press Refresh, wait for notification, then press Refresh content in main menu again. After that the new content is added. I hope it's just a function still in development, and will be stream lined soon
Video of it
1.
3. The site I normally buy off has told me the pro max is €170 which seems a bit extreme so just wondering if there's a cheaper alternative for Eu ?1. No, at least not yet. Hope it will be implemented some day. Creating XC Api Portal with same data is better solution.
2. Yes
3. The prices are static, don`t think it will be in next time cheaper.
2. Yes
The prices in the Netherlands are all around 170 euro for the Z11promax!
I have a very valid question.
Will there be a "pause button" when you record to get rid of stupid commersial.
If not, whats the point of getting Z11 pro max??
Seriously...
Cheers
/Zen
No problem here...... Everything opens fine.
your two reports are moved to other thread. I did open new one, only for reports.
@All
For bug or Issue reports please use other thread, thx -> Z11 and Mol3 Bug or issue reports
got mine today z11 verry buggy at the moment
mol 3 looks great
Hi,are you on XC or MAC ID? What do you mean by very buggy at the moment,can you be more specific?
I agree, mol3 looks good,you just need to get used to it!
i use mac on the one i cant add the one that works i conect without mac tell me how to add portal i go to mol3 and there are no placce for me to add portals
Mol3 Menu > Content Manager > Content sources
