hi guys
Yestarday during a scheduled recording, someone accidentally pushed the 'off' button -> recording finished ... This is really something that should be looked at.
hi guys
it was submitted as a feature request to implement a dialog to cancel power off/standby when an active recording is in progress.
Hi Sam, I have lately a problem he shows me
UnexpectedloaderExeption I didn’t have before what can that be the problem?
Try with deleting MOL3 cache and restart.
Is bespoken and forwarded to the devs.
you mean the beta update 11.2.2?
No, 11.2.1. Haven't tried 11.2.2 yet.
review the fixes and try if it applies to you.
Timeshift only works If I go back 5 days? If I try to watch something from yesterday or a couple of days ago I get message
Timeshift Error can't play this video?. Any idea's
Thanks in advance.
Formuler Z11 pro max.
did you try updating to the beta 11.2.2?
It has a media playback fix.
Thanks in advance.
Ik think, first connect your iptv provider.
I believe the timedhift issue is related to streams needing to be set to HLS. Sam had told me the only way to do this is via m3u connection (not xpi or Mac). Is this correct?
Apps on alternative devices such as “sticks” have the ability to switch between stream formats such as HLS and Mpegts as and when required but Formuler doesn’t have that ability for this task.
I trust that if Sam said it’s only possible in M3U then it’s likely that is the only way when using Formuler.
Even installing alternative external players on Formuler won’t help because that’s used for movies and series and nothing live tv-wise.
Hope that info makes things a little clearer
I have no such issue while scrolling through VOD or Tv Series on both MAC and XC. And that's not timeshift, timeshift is the ability to kinda record live streaming so you can go back watching something you missed, it records to the same place as normal records are stored (i use SMB local share), but when we change channel it deletes what was recorded, something like that and for me it works also on MAC and XC, while i don't use it because my provider have EPG, so when i want to watch something i've missed i go to EPG and select the live stream, it will begin the live event and then i can scroll to where i want...
On VOD when i open any movie i can scroll to whatever timestamp i want in a matter of seconds. When i can't do that is because i need to refresh stuff, that's what my provider told me, either that or change VPN ip address...
you could change the mpegts to hls(adapting to network conditions) format using the m3u url end parameter
MPEGTS:
&type=m3u_plus&output=ts
hls:
&type=m3u_plus&output=m3u8
mol will give the option to convert to xtreamcode api
Is it true that this issue hasn't been resolved yet?
It is resolved (Stalker) with latest Beta and Alternative EPG Mode. For more Informations read Beta thread.
Will epg issues ,on XC connection,likely be resolved in the next upcoming update?
In the past I have switched from stalker to XCAPI for better EPG......maybe now I have to switch back again
First I need to find out if my provider was able to solve their EPG issues.
My box uses XCAPI.
Will this issue resolved in next update? And when?
