processor t*c
  • What problem do you have with your F3?
    Does your question refer to the temperature display in the image?
    Viele Grüße / Best regards
    anmado :)
  • I found the Email from Broadcom (chipset) and if you belive or not, they say: Directly mesaured temps. from CPU are with 80-95c. normal. The chipset goes up to max. 120c and then turns the system off. Others for example, the Vu+ temp indication is measured from their own separate thermometer inside the box – this is why their Temp measurement is much lower than Formulers or from others with directly mesaured temps. from CPU.
    Why do you ask, like i know formuler did never have temp. problems with F1-F4?
    Closed the thread.
