I've had it just over a week and suddenly last night it just shout off. Red Light . Cannot turn it on.
Z10SE Box Just Died
- Hardware
- Z10 SE
- Weehaggis
Weehaggis You can hard reset the Device with a paperclip, first remove the power plug from the unit leaving the HDMI Cable attached and flip it over, to the right of the sticker there is a pinhole reset button with this button depressed "paperclip works to depress the button" , and HDMI still attached, plug the power back in untill the z10 se logo dissapears you will be prompted with a screen, remove the paperclip and choose wipe data/ factory reset on the system menu, once complete on the next system screen choose reboot system now... If your unsure you could always google "z10se hard reset"
Also check to see if your battery for the remote is not flat and the polarity is correct
I did a Hard Reset as instructed. I held the paperclip in for at least 2 or 3 minutes and nothing happened (I never got to see Logo.....just a blue screen saying "not connection")
You can Subbmit a ticket here
New Ticket - Formuler Helpdesk
They are generally really quick at responding, I might also suggest contacting your reseller prehaps you have a defective device? Needless to say, if you submit a ticket someone will get back to you... Right now they are celebrating the lunar new year and the office is closed.
but... Please do submit a ticket you can also upload a pic of the blue screen and the steps you took to resolve the issue
Did you make it to the system menu? When the z10se logo dissapeard? You have to remove the paperclip once the system menu appears
The problem is ,I can't even get to the Logo. I hold the paper clip in for several minutes and all I see is a Blue Screen saying not connected.
1. Please first connect with your reseller if Device is new resller might be of assistance
2. If you have no assistance from reseller submit ticket to formuler, *note its currently a holiday and the office is closed while the Lunar New year is being cleabrated *, someone will get back to you ifyou Submit the request
Contact your seller directly for warranty.
