Is it possible to do dish positioning using Formuler F4?
  • I need to position a dish. Can I use Formuler F4 to see signal strength? If yes then how should I do that?
    I believe this is the place where this functionality should be:
    Menu->Setup->Service Searching->Satfinder
    But when I enter this menu the signal strength is always 0%. Please see the picture.
    When I did this on my previous receiver (Sezam 7500M) it showed at least some noise at 5-8%.
  • yes but for dish calibration its not good solution. Possible but to difficult and you should also set befor searching the proper diseqc port and other [lexicon]settings[/lexicon]. Showed Transponder must be also activ
    So how should I do that? What [lexicon]settings[/lexicon] should I switch on?
    As you see, I selected a satellite and and an active transponder and got 0% signal while I expected at least 5-8% noise. I tried to rotate the dish, no change.
    I don't use diseqc for antenna rotation.
