Hi everybody,
I just bought a Z11 Pro max and i configured the remote to work via bluetooth.
The problem is when i switch off the Z11, the remote doesn't stay configurate as bluetooth ... (only IR). Do you have any solution ?
Thanks a lot !!
Hi everybody,
Thanks a lot !!
when you pair the RCU with the box, shut down and start again, does the white led flashes after 5-10sek in main menu when you press some button?
When it is pair and i switch out the box, if i try to switch on the light is orange and not white
The BT will disconnect when the device is turned off.
When you turn it back on via IR, the BT should connect automatically.
Yes but i need that it stay connected because the box is behind the wall of my tv ... do you know how can i do it ?
dont power off , use standby
you could get a remote/smart plug to turn it off at the wall and set the box power mode to to power off, then when you power on the plug your box will start up.
