disable content source, sometimes it takes up to 10 minutes for this command to take effect
Log 00000016C92D5
Log 00000016C92D5
Hi
I can confirm this, sometimes about a minute and sometimes can take up to 5-10 mins.
Confirm, not 10mins but up to 5 is correct.
but i think i also depends on the size of the content this provider has
Log 00000016C92D5
Which countries you watch?
Contact provider and ask to remove all countries. And only left the countries you watch.
If you watch only germany and unites states as example,contact provider to remove bouquettes and let germany and united stated stand.
A nice small list and the countries you dont watch, you didnt need it.
Then try again.
Confirm, not 10mins
Yes, is has to do with it so far i know.
i watch all from finland to vietnam
i have one provider with only benelux and german channels , and the same result , sometime it takes only 20 seconds and sometime several minuts , ps i have 12 providers around the world
Geez, 12? Got 3 and more then enough. Okay, small bouquet yes Benelux and germany. Then i wonder if its server side
Hi
For a test I need to disable the content of all my providers but one, still some to disable, but 2 of them took more than 10 minuten each to disable ... That's long ...
Hi
I tested it too. Disabled 2 providers. Also 6 minutes or so.
